JBarca
Oct 02, 2023Nomad II
mtnbbud wrote:
Thanks. I'll try to get pictures soon. I don't have the ability to store the trailer at my house, so it may be a few days before I get back to my trailer to take pictures. I do believe it is a Dometic. The whole roller tube with end caps assembly will need to be replaced. I kept the arms, but didn't realize I could reuse the outer roller tube. (I probably could have reused the spring also...)
When I got home, I figured out that the problem started with the lift handle. The pin thats supposed to slide up from the handle wasn't lifting out of the retention hole. When I was trying to get the lift arms to slide, the rod holding the spring tension somehow broke free and released all the tension from the spring. I was thinking I'd just replace all the hardware, but I didn't realize how much it was going to cost me.
It's a 1989 18 foot Terry Resort manufactured by Fleetwood if that helps.
I did find another brand that is currently quite a bit less money. Does anyone know anything about Aleko? It's much less money than any other brand I have found online.
The roller tube, as long as it is not bent, the tube itself can still be used. They are expensive tubes. The last tube I bought for a 19' awing was $362.42, delivered from Dometic on 4/17/19. (Pre-Covid)
The springs and some end caps may be available if the tube is still good. Again, assuming it is a Dometic.
Let's see what you have and we can help better.
John
I have not heard of Aleko, can't help on that brand.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
