mtnbbud's avatar
mtnbbud
Explorer II
Oct 02, 2023
Replacing 25 yr old awning hardware
I had to dismantle my awning hardware in camp when one side of the rod that tensions the spring came loose. I'm trying to decide how to proceed now that I'm back home. The top of the awning that houses the springs ended up getting damaged as I wasn't thinking clearly and was on a tight timeline. The extension arms have seen better days, but probably could be reused if I purchased new awning lift handles. I paid $3400 for the 18 foot trailer 10+ years ago and have kept everything working as things have worn out.
I'm not sure it's worth the $750 to replace the awning hardware, but it is nice having an awning. Does anyone know of a good source for awning hardware? Have any of you came up with a different solution that you are happy with? I'm thinking I might just go without an awning as there are lots of times I don't extend it anyway.
  • Make and model is often marked on arm near the bottom.
    NWrvsupply.com has many parts located in Eugene.
    Could be Carefree or Dometic
  • Thanks. I'll try to get pictures soon. I don't have the ability to store the trailer at my house, so it may be a few days before I get back to my trailer to take pictures. I do believe it is a Dometic. The whole roller tube with end caps assembly will need to be replaced. I kept the arms, but didn't realize I could reuse the outer roller tube. (I probably could have reused the spring also...)
    When I got home, I figured out that the problem started with the lift handle. The pin thats supposed to slide up from the handle wasn't lifting out of the retention hole. When I was trying to get the lift arms to slide, the rod holding the spring tension somehow broke free and released all the tension from the spring. I was thinking I'd just replace all the hardware, but I didn't realize how much it was going to cost me.
    It's a 1989 18 foot Terry Resort manufactured by Fleetwood if that helps.
    I did find another brand that is currently quite a bit less money. Does anyone know anything about Aleko? It's quite a bit less money than any other brand I have found online.
  • Hi,
    Please tell us the make and model of your awning. There are lots of awning makes and models within the make.
    Pictures also help explain your damage and what parts may still be available.
    I restore older campers and deal with 20 to 25-year-old awnings frequently, mainly the A&E brand by Dometic. Some parts are available, but Dometic is starting to discontinue some of them.
    Again, posting pictures of the awning hardware helps. The Dometic A & E Sunchaser series kept changing the end caps on the roller tube and then the mount to the awning arm, often until they got it right, I think. Pic's help us hone in on what vintage you have.
    I hope this helps,
    John
