westend
Jul 26, 2014Explorer
When bonding something that has a flange onto an exterior surface (I have aluminum siding) and the flange is held in compression to the siding, I like to use self-stick weather stripping, followed by a sealant around the edge of the flange. Should I have to remove the accessory, later, it is relatively easy to do. The weather stripping makes a good seal and I've never had it fail when held under compression.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
