Old-Biscuit
Dec 28, 2017Explorer III
ASME Propane tanks fall under the NFPA Jurisdiction which 'recommends' that the Pressure Relief Valve be replaced every 10 years.....but that us only a recommendation NOT a requirement.
Only time an ASME tank HAS to be replaced is it damaged from an accident/fire etc or rusted thru.
Clean up surface rust, repaint and replace relief valve---good to go.
And I would write a bad service review on that rip off joint.
They should be able to provide the documentation showing the requirement to replace tank at 10 years......hahahaha
