shastagary
Dec 28, 2017Explorer
did not see anyone consider that the tank may have been overfilled and if they went from a colder place to warmer area it could trigger the relief valve. i had it happen to me years ago scared the **** out of me when it got hot out and started blasting the relief valve once every 5 minutes until the pressure got low enough then it stopped. for the op i would have looked up a propane supplier and taken the rv there to get fixed not a rv dealer the propane dealer has the ability to empty it and fix it if needed. Propane Tank Safety Relief Valves info
