RVcircus's avatar
RVcircus
Explorer II
Mar 08, 2016
Replacing our trans filter in preparation for a long trip
I'm not sure if this belongs under DIY or TV, but here it is.
So, we have our first trip of 2016 coming up next week and though now would be as good of a time as any to replace the trans filter in the Suburban. We'll be towing about 1300 miles, so I'm running down my list of maintenance items and the trans filter is right near the top.
To get started, you need to drain the fluid from the transmission. I got lucky again and my pan has a drain plug, but if yours doesn't you'll need to strategically loosen bolts to allow it to drain from the front. Once the pan is off the filter pulls straight out and the new one pushes right back in.
Below is a list of parts and tools I used for this job:
- Transmission filter kit (includes filter, gasket and o-ring)
- ATF - our Suburban uses Dexron III
- Funnel
- 3/8" ratchet with various extensions
- 10mm socket
- Rags
Up next for the Suburban before our next journey is an oil change and brakes. This will get everything moving and stopping nicely.
Checkout our DIY video if interested:
https://youtu.be/E1qJrxkDCsA
And our related blog post:
http://www.rvcircus.com/preparing-trip-new-transmission-filter
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
