STBRetired's avatar
STBRetired
Rerouting Converter Connection
Been thinking about rerouting the 12V output connection of my PDI 80 amp converter to reduce voltage drop when in boost mode.
Current configuration:
Converter (rear of coach) -> 12V Power Panel (rear of coach) -> Battery Disconnect (front of coach) -> Batteries (rear of coach)
I intend to route new cables from the Converter directly to the Batteries with an 80 amp breaker (or fuse if I cannot source a self resetting breaker). This would reduce the length of the run fro the Converter to the batteries from about 65 feet to about 12 feet. Figure some number 4 ought to do it.
Am I setting myself up for any pitfalls by not running the Converter through the disconnect?
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 12, 2025
