STBRetired
Dec 22, 2017Explorer
Rerouting Converter Connection
Been thinking about rerouting the 12V output connection of my PDI 80 amp converter to reduce voltage drop when in boost mode.
Current configuration:
Converter (rear of coach) -> 12V Power Panel (rear of coach) -> Battery Disconnect (front of coach) -> Batteries (rear of coach)
I intend to route new cables from the Converter directly to the Batteries with an 80 amp breaker (or fuse if I cannot source a self resetting breaker). This would reduce the length of the run fro the Converter to the batteries from about 65 feet to about 12 feet. Figure some number 4 ought to do it.
Am I setting myself up for any pitfalls by not running the Converter through the disconnect?
