BFL13
Sep 03, 2013Explorer II
Reset the Trimetric AH to a Certain Number?
I don't see how to reset the AH count to a desired number. You can reset it to zero easy enough.
Anybody know if and how you can set it to a particular number? Thanks.
I have not asked Bogart yet. Will later when I get more internet access if nobody here knows.
Eg, you had a running tab but disconnected the batts for some reason and now you want to put the AH count back to what it was. Or you now have a better idea of what is "full" and want to correct the number showing.
Say you are showing -22, but know this should be 17 more so it should read -39. Instead of carrying that 17 as a correction for as long as it takes before you can get to "real full" and reset to zero, it would be nice if you could just reset it to the -39 and go from there.
