BFL13's avatar
BFL13
Explorer II
Oct 04, 2015
Reverse Polarity Fuses Circuit Question
Ok fellow scientists :) What is so special about the reverse polarity fuse circuit in a converter compared with just having a fuse on the positive output wire?
I yanked the 7355 from the trailer to put in the truck camper, and that means it is now like a portable charger with 120v input (no neg wire though, just hot and neutral with a 7355) and pos and neg DC wires output.
Its two 30 amp reverse polarity fuses are still on the DC fuse panel back in the trailer, doing nothing now. Somebody said here a while back that each 30 did half so it was like 60 (on the 55 amp converter)
So how can I wire up a set of reverse polarity fuses for the loose 7355, or can I just depend on a 60 amp fuse on the positive wire?
(AFAIK, I am also supposed to run a chassis ground wire for it now that it is no longer in its original power centre, same as you would for a deck mount.)
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,292 PostsLatest Activity: Jul 30, 2025
