- MrWizardModeratorthat might help
but it won't stop the RFI that is being radiated from the LED circuit board, where all the components are mounted - WyoTravelerExplorerWonder if a capacitor and Rf choke would across the led 12 volts.
- Ron3rdExplorer IIIOK, thanks. I'll check into that. It's not a big deal as we don't normally have the lights on when the TV is on but just wanted to see what the cure was.
- MNtundraRetNavigatorRon:
You might try using a light further from you television (or antenna on roof).
If other light fixtures work without interfering, just don't use the one that interferes when watching TV.
In my previous trailer, the florescent light over the dinette caused interference. We had plenty of other lights to use so only used that one when TV was off. - tenbearExplorerLike Gdetrailer says.
All of my lights have been changed to leds without regulators. I have had no problem with voltages as high as 14.4v, the max output of my converter. - GdetrailerExplorer III
Ron3rd wrote:
Our new trailer came with LED lights throughout. Sometimes when a TV is on an an LED light is switched on, the image on the TV screen freezes up. Turn the light off and it goes back to normal. Any way to remedy this?
Replace the LED with one that does not have a regulator..
The constant current regulator built in is generating a lot of RFI (Radio Frequency Interference) which is pretty darn hard to minimize or reduce.
The downside of this is the LEDs that do not have a constant current regulator may have a very narrow voltage range and may not tolerate the converter output voltages which can easily exceed 14.4V..
Good chance the fixture is sealed so in a nutshell you may have to replace the entire fixture.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
