parkmanaa
Mar 01, 2019Explorer
On some makes/models of 5ers the mfg. has made provisions for adding a 2nd unit.
If they did on your's, it would be quite easy to accomplish. They cut a hole the standard 14" x 14" you need, it's just covered by veneer inside and rooftop. Also, the wiring is usually in place for it at that 14" opening.
Agree with other's, techs don't like to service the rooftop air, but some will although I seriously doubt trying to add freon will help. If cleaning coils does not work you will probably want to pursue that 2nd A/C rooftop unit. A 13,500 btu would probably be sufficient for the 2nd unit.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
