RDalr
Mar 02, 2019Explorer
Thank you all for your comments.
My unit is 50 amps. I should have bought a second ac when I first bought it. The compressor kicks in but when I check the cool air temp, I get a reading of 64 degrees. If it was working correctly, I should see a cool air reading of 42 or 43 degrees.
Is there a thermostat or thermometer inside the ac which commands cooler air? If so, is its placement inside the ac critical to achieving that goal?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
