opnspaces
Mar 02, 2019Navigator III
RDalr wrote:
Thank you all for your comments.
My unit is 50 amps. I should have bought a second ac when I first bought it. The compressor kicks in but when I check the cool air temp, I get a reading of 64 degrees. If it was working correctly, I should see a cool air reading of 42 or 43 degrees.
Is there a thermostat or thermometer inside the ac which commands cooler air? If so, is its placement inside the ac critical to achieving that goal?
Unfortunately the way AC works you should only see a 14 to 20 degree difference between the temperature of the input and output air. So to get 42 degrees out of the vents it would be 62 degrees in the coach.
If you have a ducted unit you should look for air leaks on the output. On my trailer I pulled the intake grill off the ceiling and I could see many places where the cold air was either mixing with the warm air, or sneaking around the ducting and into the attic space. If you find the same in your system you can fix it with some foil ducting tape from Home Depot or other home improvement stores.
Please note this is not the standard dollar a roll cloth duct tape and we all use around the house. This is a metallic tape with a peel off butyl backing that they will sell in the aisle with the HVAC ducting.
Tape
On my trailer it took me about 20 minutes with a scissors to reseal the airbox in my AC and now the vents blow much more efficiently. Of course the irony of all this is I never use the AC. As in it's probably only been turned on a total of 5 times in the 13 years I've owned the trailer.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
