meleavingsoon
May 27, 2016Explorer
Roof top A/C not cooling properly
Hey all...don't know if this is the best section to post this question but seemed like a great place to start.
We purchased a 2007 Cardinal 5th wheel with original Duo-Therm 15,000btu roof air last year and enjoyed the air conditioner all summer...worked great. Turned it on couple days ago and seemed to run fine to begin with. But after several hours the air temperature started to warm a little and progressively get warmer.
Before I first started it up I got on the roof and removed the cover and did a simple cleaning. Then turned it on and started working great. The coolant line started sweating as it should and was very cold and the return line was very warm. Ran great like that for many hours. But then several hours later the interior air started getting warmer so I went back up on roof and checked the lines and now the cold line is only slightly cool and not sweating.
It almost seems as if I have lost my Freon?? Is there something else I should check? The unit seems to be running fine? I don't see any place to add freon???
Appreciate any help....thanks, Phil
