brash1's avatar
brash1
rooftop air
I have a 96 tioga montara class c. The ac unit has an issue I've diagnosed but I can't find the replacement part. It needs a new circuit board that has the compressor relay on it. The info printed on the board is" RVRB 7330A321". I have no idea of the manufacturer of the roof top ac. The badging is long since gone. Is there a data plate located somewhere on these units?
  • If you still have trouble finding the correct part you could contact http://www.corecentricsolutions.com, a company that rebuilds electronic boards to original manf. specs. Used them many times in the home appliance repair industry.
  • Part number 8330-3851 board, box and freeze sensor. Plug and play replacement.
  • I bought a new board once but cannot remember the type or circumstances.
    i do remember talking to a guy at PPL who knew the answer and specs on the board i was looking at and came up with the exact same replacement.
  • You have a COLEMAN, now called Airxcel. You will need to call them to see if the part is still available. Doug
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
