ScottnSherrie's avatar
Oct 28, 2013
Rotor and pads and bearings. Oh my!
Left rear brake disc (yes, rear disc) overheated last trip out to the point the brake fluid boiled and disc was smoking. Whether it was a sticking piston or internal kink in the final section of brake hose is moot now. Need to replace hose and caliper seals at a minimum. Left rear was the only one with an issue as I limped home (only 20 miles) by stopping every few miles and checking the temperature of each disc. Only left rear was overheating. Even with frequent stops, it got over 400 degrees by time I reached the house.
Talked to resident automotive expert at work and he said the disc was probably softened due to annealing, the seals in the caliper ruined due to overheating and grease cooked away in the bearing.
Been researching and I read the pads get glazed and ruined when overheated.
So now what was going to be new hoses and maybe a caliper has turned into, at minimum; new caliper piston seals, new pads, new hoses and repacking the bearing.
At worst it could be all that and new bearings and new caliper instead of rebuilding.
I will replace all the brake hoses. I think 25 years is more than long enough.
Anyone ever had a dragging rear caliper like I described? What was your experience with the work required to set things right again?
Having RV issues? Connect with others who have been in your shoes.24,251 PostsLatest Activity: May 17, 2025
