I had to peel back a corner of my rubber roof to repair the wood underneath. I will need to glue the rubber back down. Is there a specific type of glue that I need to use?
Hi—you can use a non-solvent based contact cement. Make sure both surfaces are dry and coat with the non-solvent contact cement. You have to be careful laying the rubber back down as once it makes contact, it cannot be moved. Sort of like applying contact paper.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
