I had to peel back a corner of my rubber roof to repair the wood underneath. I will need to glue the rubber back down. Is there a specific type of glue that I need to use?
I just had this very same conversation with the folks at Alpha roofing... They suggest using - 3M 77 spray adhesive
They have done a ton of studies and found this to be the best... spray the roof area to be replaced, reconnected , spray the membrane while BOTH are tacky press together and use roller to adhere the 2 together...
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
