jrnymn7
Dec 18, 2013Explorer
Peg Leg wrote:
Back in the 70's I used to work on the repair bench in Delco Remy's alternator plant. The stator and rotor determine the alternators output. I remember changing my 77 pickup from a 37 to a 55 amp alternator. They used to stamp the output on the outside of the case.
What are you running for house batteries? Add a house battery or two and with a isolator and run the inverter off of them while the alternator charges them.
i have four transcanada 6v golf cart batteries in series/parallel for 440 a/h. are you suggesting charging them off the alternator along with a couple more? i don't have room for more batteries in that compartment, nor is there much room anywhere else. my best bet may be to put a larger battery where the starter battery is, as suggested earlier, and go with a separate system just for the a/c.
there are some pretty high output alternators available now; like 200 amps; which may or may not raise wiring issues?
