jrnymn7
Dec 19, 2013Explorer
jauguston wrote:
The second alternator idea just complicates things and is not needed. If the OP has a 100a or better alternator that is all he will need.
It is very common to have a second wire from the alternator output to go to the back of a truck and on to the battery in a RV trailer. This circuit often has a continuos duty solenoid in it that is activated by the ignition key so it is powered only when the key is on and the engine is running. Something like that between the alternator and the house battery would prevent discharging the chassis starting battery. That setup is also common in motorhomes to charge the house batteries while driving.
i guess the other issue would be the quality of charge from the alternator? obviously there would be no multistage "smart" charging, only an old time absorption charge at a steady 14.3 volts. ould this greatly affect the life of the batteries?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
