Peg_Leg
Dec 20, 2013Explorer
With 4 golf cart batteries already installed you should be able to run a inverter for the AC unit. Use the golf cart (GC) batteries to power the inverter not the starter battery.
The GC batteries should already have a charge wire with a isolator. The isolator looks like an old Ford starter solenoid that mounted on the fender well but is rated for continuous duty.
The isolator allows the GC batteries to charge from the alternator when the vehicle is running. Then it shuts off when the engine is off to keep the house from pulling down the starting battery.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
