Olive600's avatar
Olive600
Running AC off of my home's current/Please Respond
I've been told that running the AC for my 2005 B Touring Cruiser Gulfstream off my house current can burn out the AC's air compressor. I've also been told that's not true, that the worst that will happen if there isn't enough current is that a fuse will blow. Unfortunately the difference of opinion has turned into some very bad feelings between friends. I'm still shaking. Please help me understand if you can. I'm new to all this. Evidently as an older, single woman I will be lied to and cheated at every turn. At least that's what I'm being told. (Yes, I'm so upset that I'm sniveling 8-) )
Thanks
  • You can do it if:
    If your rig is wired for 50 Amp service:
    You have a correctly wired 50 Amp RV outlet into which you can plug the RV.
    If you need an extension cord, use only a 50 Amp RV extension cord.
    If your rig is wired for 30 Amp service:
    You have a *correctly wired 30 Amp RV outlet into which you can plug the RV.
    If you need an extension cord, use only a 30 Amp RV extension cord.
    * Make sure the electrician knows how to wire an RV outlet.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
