BradW's avatar
BradW
Explorer II
May 24, 2018
RV A/C Wall T'stat Wiring
Do RV manufacturers normally run the heat wire to the wall thermostat even if the A/C unit does not have heat?
I'm asking because I may order a new rv which has a Coleman A/C unit without the electric heating element and it is controlled by a wall t'stat. The t'stat has the heat setting on it.
I want to add the electric heat element and I'm wondering if I will have to add another control wire from the unit to the t'stat.
Thanks for any help,
BradW
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
