Elkhound's avatar
Elkhound
RV Fridge Cooling Unit
Hi All,
Has this happened to you? You are camping and the fridge in your RV stops working. You do the diagnostics test and it shows your cooling unit is bad. I had this experience just last month. Upon research I was amazed I was looking at over $1K in parts and labor to replace the cooling unit. I am a general contractor and so I was not about to pay that kind of money. I am not sure why so many of us are afraid to tackle service work on an RV like it is something special.
I found a resource for cooling units wholesale. (PM me if you want to get connected to a cooling unit) All the installation instructions can be found on the web but it is relatively easy to do yourself. Mine took about 4 hours (Norcold 621). I ordered the new cooling unit and then took the fridge out. You disconnect the gas and the power and then on mine it was only 4 screws to pull the fridge from the opening.
Upon getting the unit out there is some minor disassembly and a few screws to get the the cooling unit portion removed from the back of the fridge. At this point I discovered why my unit had failed. They had insulation installed around the unit and up the vent shaft. But Keystone did not properly secure the insulation going up and it had fallen down and was preventing airflow up the back of the unit. That is why the unit failed prematurely.
Once removed you clean old mastic and apply new thermal mastic and expanding foam before you place, align and secure the new cooling unit to the fridge.
Then you put the unit back in the opening and make your connections on the back and you should be back in business. I save $800 from the repair I was quoted and also got improvements by securing the insulation. I added a fan with thermal switch to improve draft in the vent across the coils and also added a fan to circulate the air inside the fridge that I found on ebay, that really helps to create uniform interior temperature.
Never be afraid of taking on RV projects they are as easy as your home projects. :)
  • rhagfo's avatar
    rhagfo
    Explorer III
    Elkhound wrote:
    darsben1 wrote:
    Yes we know Amish cooling Units are well Known brand.
    Yes the Amish units are great. I did not go with one of those. I put in a re-manufactured unit that had a 3 year warranty, same duration as the Amish unit, but about half the price.
    I am posting because there is not a lot of info on fridges or cooling unit actual repair that I was able to find when I was looking. I had to piece together the info on my own.
    Sorry to hear that, when the cooling unit failed in our first 5er an 86 King of the Road, the cabinet was in great shape, and I had time to do research. Called the company below and had a talk with the owner, discussed the advantages of Amish units. Amish don't use electricity, the only cooling they use is absorption, they are experts. I bought a rebuilt unit and was truly impressed with it my Norcold with a four position temp control never wnet above #1 of four settings.
    RV Cooling Unit Warehouse
  • I feel your pain. Why hire some OVERPRICED General Contractor to do repairs or remodeling on your house when you can tackle the job yourself? BECAUSE, most people do not have the time or want to tackle the job. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
