BurbMan's avatar
BurbMan
Explorer II
Aug 15, 2017
RV Outlet NEC Code Question
Hi guys,
I currently have an outlet installed on a pole by where I park the RV. The outlet is a 30a amp RV outlet and is 30a 120v (NOT 240v).
It's fed directly from the panel with #10 wire connected at the main panel to a 30a single pole breaker.
I would like to change out the outlet to a box that has the 30a outlet, along with a 20a GFI and two breakers, one 30a and one 20a, one for each outlet. This is an outdoor weatherproof box like you would see at a campground or RV park.
Reasons for the change are:
1) I like having a breaker so I can plug in the RV and then power it on. This eliminates wear and tear from arcing on the plug.
2) It would be nice to have a convenience outlet there. I can't just add one without it being protected by a 20a breaker.
Ideally I would like to feed this with the 30a 120v circuit that's already there.
Most of the time the RV draws very little power, it's only trickle charging the batteries. It will draw power with the a/c on, so just won't be able to use the conveience outlet at those times. I'm not looking to increase power capacity at the outlet, and I have no need for 240v there, it would be nice to plug in an extension cord without having to unplug the RV.
Can I feed this new outlet with the existing circuit, or is this considered a subpanel because it has breakers? Do I need to feed it with a 30a double pole breaker like it was a sub panel?
I know I "can" wire it from the existing circuit with no issues but am wondering if anybody knows what the NEC rule is on this.
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 02, 2025
