RoadXYZ
Feb 22, 2014Explorer II
smkettner wrote:
Most likely you mean 30 amp main cord connection? The converter will have a separate DC output rating. Most are 45 to 60 amps (12vdc) even with a 30a (120vac)plug.
You will need to open the power distribution panel(stack of fuses and breakers) and get the model number. If it is a separate deck mount converter you will need to dig in and get the model number directly off the unit.
Thank you .. will give this to Hubby ...
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
