selah44
Jun 09, 2013Explorer
Schwintek two motor slide out retaining screw
I checked the other wonderful posts but none were exactly like the issue I am having. My fifth wheeler Vengeance is brand new but the Schwintek two motor slide out doesn't work. Slide unit is stuck fully in. One motor works and moves properly but the other motor is dead (confirmed bad motor). The motors are accessible from the inside of the RV but held in place with one screw that is accessible only from the outside. Very nice manuals and videos shows that you remove the motor retaining screw and push the motor one inch up and out. One problem. The motor retaining screw is located on the outside and I can not move the motor upwards one inch up to disengage the motor from the gears (thus mechanically stuck). Unplugging the motors to take the brake off doesn't work. To recap, a stuck dead motor that is frozen and no way to get to the retaining screw. Up to a $500,000.00 reward for a good answer. That is correct.... somewhere between $0 to $500,000.00. Just having fun. Thanks for the help.
