I can't keep my Onan KY4000....H generator running unless I spray a continual mist of seafoam treatment into the air cleaner. Would this mean carb issue or control board issue?
FUEL could be a clogged carb, could be a bad fuel pump, or clogged filter
or Not enough gas in the RV tank, you do have at least a 1/2 tank right somewhere around 1/4 the generator pickup can no longer reach the gas the generator pickup is shorter than the drive engine pickup tube
