Ldworak's avatar
Ldworak
Seafoam Treatment
I can't keep my Onan KY4000....H generator running unless I spray a continual mist of seafoam treatment into the air cleaner. Would this mean carb issue or control board issue?
Thanks
Len
  • FUEL
    could be a clogged carb, could be a bad fuel pump, or clogged filter
    or Not enough gas in the RV tank, you do have at least a 1/2 tank right
    somewhere around 1/4 the generator pickup can no longer reach the gas
    the generator pickup is shorter than the drive engine pickup tube
  • I pull the fuel line off the carb while trying to start and its being presented in a continuous flow.
Having RV issues? Connect with others who have been in your shoes.24,298 PostsLatest Activity: Aug 11, 2025
