DrewE
Nov 13, 2017Explorer III
You don't need an earth ground for the 12V system to work. The terminology can be confusing, but chassis ground (which is what is in play here) is a separate issue from earthing. It's somewhat unfortunate that both are commonly called "ground."
I doubt the connection to the truck is your problem; at least, it is not the main problem. You should not have wires becoming incandescent just because you don't have the truck connection in place.
