MrWizard
Nov 13, 2017Moderator
You need to get into the converter charger 12vdc distribution
You have lost the main negative return path between battery and camper body
Broken lose wire, dirty corroded connection
The battery neg is connecting thru the furnace to camper connection
The power return path for the camper is going thru the furnace wire
Which is not large enough, for the whole camper , and all loads
