DrewE
Nov 14, 2017Explorer III
I predict that if you remove the furnace (and its ground wire), nothing electrical will work anymore--or, at least, some things electrical will not work. It shouldn't be that way, but it sure looks like your chassis ground/negative return is all going through that wire. Remove it and you don't have a circuit and your stuff can't run.
You would also need to safely cap off the propane connection to the furnace.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
