time2roll
Nov 14, 2017Nomad
That much power has to come from somewhere. Does anything work if that ground is disconnected? Have you checked continuity of the main ground bus to the frame? Have you pulled all the fuses to see if that cuts the power? Most these circuits are fused so that much power should open a fuse. Are the fuses the right size? Is the wire undersized? Are you even sure it is 12v power? If you think the power is from the thermostat... did you disconnect it?
Electricity is all about divide and conquer. You need to start splitting up the system until something changes.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
