Rvpapa
Nov 14, 2017Explorer
QUOTE "The camper battery is NOT grounded to the camper chassis, but the propane tube leading to the furnace is grounded to the camper chassis....So when the trailer cable was removed, everything in the camper was pumping out from the battery, then trying to ground to the propane tube into the camper chassis, which never leads back to the battery, which causes the smallest wire in the system to smoke up."
So in effect you are useing the PROPANE line as a main battery ground. Now that IS scary.
Art.
Art.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
