- Star_GazerExplorerMany times these fridges are not installed correctly to begin with. The specs call for no more than a certain space in front of the cooling fins, this is so that as air moves up it actually goes thru the fins. If the space it too large then air goes past the fins and does not cool them enough. I have added a deflector to mine that forces air closer to the fins. And if is really hot I will set a fan pointing towards the bottom and remove both upper and lower vent covers. Shade is a must as well.
- azdryheatExplorerIt's triple digits here in Tucson and my refrigerator has no trouble making ice cubes. It's plugged in to shore power if that makes a difference.
- otrfunExplorer IIExterior fans will help. We've found it improves cooling about 2-4 degrees when ambient temps are really high.
We've camped in 110+ AZ heat many times. Even a perfectly operating propane frig with double exterior fans will have trouble maintaining 40 degrees in this kind of heat. If you access the frig more than once every 2-3 hours during the heat of the day you'll be lucky to stay below 45. - _1FlyboyExplorer IIX3 on fan’s & get side in shade…
- larry_cadExplorer IIPropane refrigerator MUST be level also.
- harley-daveExplorer II
sch911 wrote:
X2 This is what we did also. Also keep the refer at maximum cold (9) setting, cool inside the coach, shade the vents outside the RV and don't open the refer as much as possible.
I have two 12V computer fans blowing air upward in the back of the fridge. They are mounted about half way up the back of the flue. Getting the heat to rise out of the flue is the key.
Dave - sch911ExplorerI have two 12V computer fans blowing air upward in the back of the fridge. They are mounted about half way up the back of the flue. Getting the heat to rise out of the flue is the key.
- valhalla360NavigatorIf the cooling unit is 150F (not sure of the actual temp but it's pretty hot).
- If there is minimal airflow, the air around the cooling unit may be 130-140F, so only a 10-20F temp difference.
- If you push 110F air in, that's a 40F temp difference which will extract more heat from the cooling unit.
That said, 110F can be problematic. - MrWizardModeratorFans help, the move more air over the coils, yes the outside air is hot, but the heat exchanger coil is hotter, the more air flow the more heat removed from the coolant, the better the absorption RV fridge will operate
Parking so the fridge side of the RV is not in the afternoon sun helps, put out the awning, hang a tarp, park next to a tree, anything that shades the back of the fridge, helps - groundhogyExplorermini swamp cooler.. see...
www.arcticairpurechill.com
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
