I didn't want to hijack anyones tread so figured I'd ask here. I've heard a lot of talk about replacing the regular tv booster wall plate with the new Sensar Pro and have read it's a direct replacemen...
You will also not be able to use an outside cable connection to power a satellite antenna if you use the Sensar Pro. However, you can add an A/B switch to that coax end where your current power supply is (or where the Sensar Pro will be) and send one output from the A/B to the Sensar and the other output to the satellite receiver and that will allow you to use the one cable or the connection of your choice.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
