I didn't want to hijack anyones tread so figured I'd ask here. I've heard a lot of talk about replacing the regular tv booster wall plate with the new Sensar Pro and have read it's a direct replacemen...
Well, that's my point! What a PITA to try to run new cable from outside to your AV area. Especially since the factory cable works perfectly well. Even the Directv website states that the big advantage of SWM IS BEING ABLE TO RUN 6-12 boxes on existing cable!!! Their tests aren't frequency/attenuation based; they test RESISTANCE to assure that it can handle the PI load.
You DO NOT need to run a new run unless your existing cable is faulty.
Bad advice.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
