- mena661ExplorerThanks Niner for the confirmation. Good info to know.
- NinerBikesExplorer
NinerBikes wrote:
mena661 wrote:
Ok, DW and I went out for a last minute day trip in the MH. All boondocking. Bank was only down 14Ah total. Got home, adjusted MegaWatt to 14.7V (it tends to rise a tenth) and let her rip. Amps went up to 36.4 and hung out there for a few minutes then tapered to 29. No weird noises or other signs of protest.
This pretty much matches what I saw when the temps I was charging up at were in the 80's to 90's F. For some reason, firing up the Mega Watt S350-12 in 17F temps really ramped the amps up briefly to 40 amps. It was coming down about an amp a second or two in the first 10 to 15 seconds and locks on and steadies at 29 amps. BTW, that is the only time I've seen my Honda EU2000i smoke steam, and continue to do so, even after warmed up 3 or 4 minutes. Perhaps a lot of water in the fuel, or methanol?
This was on a single T-1275, don't know if a C5 charge rate is hard on this battery, Mexwan has suggested that it's best to not whomp on the amp charge rate too hard on this battery, due to it's construction and poor acid to plate ratio, due to it's shape and size. - NinerBikesExplorer
This was on a single T-1275, don't know if a C5 charge rate is hard on this battery, Mexwan has suggested that it's best to not whomp on the amp charge rate too hard on this battery, due to it's construction and poor acid to plate ratio, due to it's shape and size. - mena661ExplorerOk, DW and I went out for a last minute day trip in the MH. All boondocking. Bank was only down 14Ah total. Got home, adjusted MegaWatt to 14.7V (it tends to rise a tenth) and let her rip. Amps went up to 36.4 and hung out there for a few minutes then tapered to 29. No weird noises or other signs of protest.
- mena661Explorer
NinerBikes wrote:
Mine is the 30A and I have it set at 13.65V.
What do you have the voltage set at on your Mega Watt, and is it the 30 amp or 36 amp model? - jrnymn7ExplorerHas anyone tried paralleling either a pair of mean wells or mega watts?
I know some of the mean wells are constant current limited protected, but are the mega watts as well? - MEXICOWANDERERExplorerAC power sagged to 22 volts a couple days ago. Blew some lithium and NiMH chargers. The cheapo and the WFCO shrugged it off. The Lifeline and Samlex did their job and it was only after the transformer rectified Endless Breeze started spinning at 30 RPM did I notice the burnt-umber-outage was underway.
I've been doing scans on the open-chassis WFCO with an IR. No way in hell in the OEM fan going to keep an enclosed WFCO cool enough for my taste. Second fan gets added tomorrow.
Stupid crippled left hand stops me from soldering-in swapping genuine 10-turn cermet pots in place of the .00002 cent OEM cheapo pots. Gotta find an electronics place that I trust to do the job right. Need to find some 1/4"X20 1/2" screws for the rectifier. Poco a poco. I am playing jump-rope with a new-to-me Galaxy phone. It's winning. - landyacht318ExplorerWe need a franken borg charger thread mex.
- MEXICOWANDERERExplorerThe Cheapo when plugged in charges the caps because it has no switch on the AC.
jrnymn7 wrote:
I'd like to compile a list of AC line start-up currents on the various units, for matching up to smaller generators, as well as their max amp outputs.
I can tell you that the 30 amp Mega Watt, when first turned on on a Honda Eu1000i, at 7000 feet, with non ethanol fuel, is going to run that 1000 a bit hard the first 3 or 4 minutes, so make sure the generator is warmed up well before you flip on the switch on the Mega Watt, cause the motor is going to get a bit of a bark to it for maybe 5 minutes or so.
