sealevel_ram's avatar
sealevel_ram
Shore Power at Home Wired Wrong and Lightning also.
Last August I built a MH garage. Had a 30 amp outlet installed. Have had my unit plugged in when at home since then. Everything OK.
Had an electrical storm (This IS Florida). Did some damage to my electronics in house. Blew the breaker in MH garage. Found a little burned rectifier in transfer switch. Reset breaker. The 110 outlets didn't work. A/C worked. Chassis batteries were dead. With MH motor on, had 12 volt lights, etc. Charger/inverter panel in unit lit up and said "check batteries". Generator power would not transfer to coach.
Strange thing is, when checking, I found the neutral and hot wires were reversed on the 30 amp outlet, AND there was no separate ground bus in the box as required by code, with the obligatory ground rod. (So much for electric inspection.)
Have now installed a new transfer switch and bought new chassis batteries. The 30 amp outlet has been now wired correctly. I am hesitant to plug in shore power in case the inverter/charger is kaput.
Would like some expert opinions, and/or ways to check without screwing this up more. Thank you.
