scarpi
Jul 21, 2013Explorer
Shurflo water pump problem
Hi all. Ok I've done some searching on the forum about this but I can't find a similar issue so I'll post it. I have an 09 PW class B. I am getting ready for a short trip tomorrow and all of a sudden my water pump is not working properly. After sanitizing my fresh water tank, I turned on the water pump and faucets to drain the fresh tank into the grey tank. I was plugged into shore power and the water pump was making it's usual noise going on and off as usual when I opened the faucets but the water flow was less than half the normal flow. It took forever to drain my 24 gallon fresh water tank into the grey tank. I looked at the pump and there are no leaks and I have not changed anything since I last used the RV and the water pump was working fine. I did not change the valve settings on my water heater because I don't have to winterize my RV here. So some thing has happened to cause a sudden decrease in the water flow. The faucets work and toilet flushes but the flow is very low now. We are leaving tomorrow on a short trip and it is Sunday so I can't get parts. But we will mostly be connected to city water at the RV park so I won't be using the water pump much except if we go to some picnic spots. Anybody got any ideas on what the problem could be? I got out the owners manual and it is a Shurflo series 2088/2093 water pump that is now about four years old but not used that much. Thanks, Don.
