scarpi's avatar
scarpi
Shurflo water pump problem
Hi all. Ok I've done some searching on the forum about this but I can't find a similar issue so I'll post it. I have an 09 PW class B. I am getting ready for a short trip tomorrow and all of a sudden my water pump is not working properly. After sanitizing my fresh water tank, I turned on the water pump and faucets to drain the fresh tank into the grey tank. I was plugged into shore power and the water pump was making it's usual noise going on and off as usual when I opened the faucets but the water flow was less than half the normal flow. It took forever to drain my 24 gallon fresh water tank into the grey tank. I looked at the pump and there are no leaks and I have not changed anything since I last used the RV and the water pump was working fine. I did not change the valve settings on my water heater because I don't have to winterize my RV here. So some thing has happened to cause a sudden decrease in the water flow. The faucets work and toilet flushes but the flow is very low now. We are leaving tomorrow on a short trip and it is Sunday so I can't get parts. But we will mostly be connected to city water at the RV park so I won't be using the water pump much except if we go to some picnic spots. Anybody got any ideas on what the problem could be? I got out the owners manual and it is a Shurflo series 2088/2093 water pump that is now about four years old but not used that much. Thanks, Don.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 02, 2026
