PerryB67
Dec 16, 2021Explorer
Ivylog wrote:The Aili only tells you in realtime what is going on. That's great if everything is working properly. It's only slightly better than a cigarette plug voltage meter. I want to know the net amp use overnight, or if there was a voltage spike that ruined, or about to ruin, my batteries. BTDT! A monitor with history will do that. Unless Aili recently came out with a new meter that stores some history it's merely a realtime meter. You'll understand what I'm talking about when you have a problem, but the cheap Ali is just that, cheap.
The second reply…Aili for $41 is the best suggestion. With only one battery you do not need the 350A size. I’m using one and it tells you everything you need to know and easy enough to install.
If all you want is a simple realtime meter then the Aili is decent, but very limited. However, if you really want to monitor what's happening with your system over time then the $130 for the Victron SmartShunt is a far superior choice.
Plus the Aili is harder to install than the SmartShunt .
Enjoy,
Perry
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
