Naio's avatar
Naio
Explorer II
May 11, 2017
Sizing jack stands for wind load?
I often camp in windy places.
In my current, small van, I sometimes have to lift the tires off the ground to get stability. I use jack stands that are each rated for my whole gvw, to allow for the increased load with wind gusts. 45 mph gusts are common. (When they reached 60mph this winter I went to a motel for 2 nights, but my cat hated that. I thought my little van might blow off the jack stands!)
I guess my current ones will be ok for the front of my new van, but I will need a stronger pair for the rear.
Is gvw a good guide? Or how SHOULD I estimate wind forces and strength?
Are HF stands ok?
Thanks, always.
  • DrewE's avatar
    DrewE
    Explorer III
    Wind isn't going to put more than the full vehicle weight on any one jack stand, since the applied force on the van is in the horizontal rather than the vertical plane. Your approach is safely conservative.
    Do bear in mind that jack stands are often sold in pairs and rated for load for the pair, with each of the stands actually rated individually for only half that weight. It's sometimes a bit misleading, with the small print taking away what the big print giveth.
  • If each stand is rated for the full gvw then that is not going to be the issue. The only issue I can think of is the stands stability in two places. The part that is actually touching the vehicle ie will the vehicle slide /get pushed off without knocking the stand over or perhaps better said the connection between the stand and the vehicle and secondly the base of the stand or footprint. Is the footprint of the stand more than the tire it is displacing? Bottle jack perhaps not, actual jack stand probably ok. I would park nose or tail into the wind and only raise the vehicle the least amount as possible. I seriously doubt a 60mph wind is going to blow over a van but it may blow it off the stands if they are not appropriate.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
