joebedford's avatar
joebedford
Nomad III
Apr 05, 2026
Slide Controller override switch replace?
The rubber / plastic button actuator on my Schwintek / Lippert slide controller was knocked off. I want to replace the switch indicated by the red circle. Has anybody done this? What switch did you use? I found one on Amazon that looks the same and is about the right size 6x6x5mm. I don't want to spend 100s on a new controller because this one works except for the button.
1 Reply
  • I wonder if the number is on the bottom of the switch, which means you will have to remove it to see which one to get.
