salem
Dec 28, 2014Explorer
Slide Out Issue
The guy across from me in the RV park has a 2005 Jazz, by Thor. His slide will go in, but not out. He's thinking probably a switch issue. What do you think? Also, if he has to manually crank it out, does he have to go underneath and put a ratchet on the motor? On a lot of RV's you use a long rod inserted into a hole on the outside, but he can't locate one on his. Thanks folks.
