Hslag's avatar
Hslag
Slide out problem
Ok the problem is that my small slide will come in until it is tilted so much it will not move have ho pull the top in and have someone push switch to get it to come in any sudjestions I was hooked up to 30 amp service! Was not running on batterys
  • Appropriate lubrication does wonders too. Slides are finicky mechanical beasts, and like other objects that need regular maintenance, the right lube in the correct locations usually corrects the issues.
    Unless there's damage due to the lack of lubrication and/or other causes...
  • Question: When it DID work previously, did it "tilt?"
    Tilting indicates binding in my book. If the bottom is going in and it tilts outward at the top, something is binding at the top.
    On a 2007 travel trailer it could be as serious as structural failure of the trailer frame. It's old enough, and probably one of those wonderful Lippert frames. A friend had to trade his in because the frame failed at the slide.
  • Try jumping from a vehicle battery. Often the converter alone will not put out enough current to operate the slides.
  • Hslag wrote:
    It's the small one thAt has bunk beds! Travel trailor and it is a 07 model.by the way I did not have the battery in it do to winter storage!!
    Most slides will not operate correctly on shore power alone. They need a fully charged battery installed, or jump from truck battery with heavy duty cables, direct to trailer battery cables.
    Jerry
  • It's the small one thAt has bunk beds! Travel trailor and it is a 07 model.by the way I did not have the battery in it do to winter storage!!
  • Is this the bedroom slide? Or a small side in the main body of the trailer? Trailer or 5th wheel?
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
