CA_Traveler
Jun 04, 2019Explorer III
Nice solution. I tested my slide out refer at 110F w/o A/C and it would not adequately cool. OK with the A/Cs on but it runs a lot.
I've just completed installing 2 fans on the plywood where you have the aluminum. With the vent attached the fans are adjacent. Tests show a lot of hot air expelled.
I have a inside switch for 1 fan, off, 2 fans and will be testing this setup this summer.
I plan to add a very high temp thermostat and a lower temp one to cycle the fans.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
