danoren's avatar
danoren
Slide out tilting
The big slide with the dinning table and the hidabed is leaning a bit down when it is open,the beam under it is touching the lower part of the hole on the frame so when I move the slide in/out it scratches the beam.
Any suggestions besides going to an RV repair that I will be doing soon?
Thanks
  • I just had my slide serviced because is was rubbing against the top of the slide motor. Apparently Fleetwood is aware of this problem but is not issuing a notice to owners because they would have to pay for a recall and repairs. Even my extended warranty would not pay because they said it was a known defect and Fleetwood should be responsible for the repairs. Not sure if this is the same problem you are having, but I would contact the manufacturer customer service and report the problem immediately and document all communications with them. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
