Dutch_12078
Feb 24, 2018Explorer III
As said, most do have a manual override of some sort, depending on the slide mechanism. Our coach for instance, came with a long crank that's fitted through a small opening where it engages with the drive motor/gear box assembly to retract the slide if needed. I've tested it, and while it does give your shoulders a workout, it will get the job done.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 24, 2026
